kmataruse Posted April 27, 2005 Report Share Posted April 27, 2005 I'm confused about the NH900 batteries. I see that it comes with the gumstick and from reading posts it sounds as if I should upgrade that soon. However, I wanted to use the AA battery by itself for most of my needs. 1. Does anyone have opinions about using just the AA battery and not the gumstick?2. The manual says to use an Alkaline AA. Does that mean I cannot use my NiMH AA batteries?3. My player came with Sonic Stage ver.2.0 Can I get version 3 somewhere here or elsewhere?Thanks.Kim Quote Link to comment Share on other sites More sharing options...
Ishiyoshi Posted April 28, 2005 Report Share Posted April 28, 2005 I'm confused about the NH900 batteries. I see that it comes with the gumstick and from reading posts it sounds as if I should upgrade that soon. However, I wanted to use the AA battery by itself for most of my needs. 1. Does anyone have opinions about using just the AA battery and not the gumstick?2. The manual says to use an Alkaline AA. Does that mean I cannot use my NiMH AA batteries?3. My player came with Sonic Stage ver.2.0 Can I get version 3 somewhere here or elsewhere?Thanks.Kim←Answer to 1: NiMH would be more efficient for daily operation. But no problem using just AA battery.Answer to 2: No, you can certainly use NiMH. AA battery act as a supplement to extend operation time.Answer to 3: You can get SonicStage 3.1 from this thread. Quote Link to comment Share on other sites More sharing options...
kmataruse Posted April 28, 2005 Author Report Share Posted April 28, 2005 >Answer to 2: No, you can certainly use NiMH. AA battery act as a supplement to extend operation time.Just to make sure I clearly understand. Are you saying that yes I can use my NiMH AA? I have a bunch of rechargable AA batteries that are not alkaline --they are NiMH AA. The NH900 manual clearly states alkaline AA and years ago I recall there were problems with some electronics when you mixed battery types. Just don't want to screw up my new machine Thanks very much.Kim Quote Link to comment Share on other sites More sharing options...
Ishiyoshi Posted April 28, 2005 Report Share Posted April 28, 2005 >Answer to 2: No, you can certainly use NiMH. AA battery act as a supplement to extend operation time.Just to make sure I clearly understand. Are you saying that yes I can use my NiMH AA? I have a bunch of rechargable AA batteries that are not alkaline --they are NiMH AA. The NH900 manual clearly states alkaline AA and years ago I recall there were problems with some electronics when you mixed battery types. Just don't want to screw up my new machine Thanks very much.Kim←Yes, indeed. NiMH AA works just fine. No problems with all my portable MD units. Quote Link to comment Share on other sites More sharing options...
kmataruse Posted April 28, 2005 Author Report Share Posted April 28, 2005 Yes, indeed. NiMH AA works just fine. No problems with all my portable MD units.←Yay! Thank you. Quote Link to comment Share on other sites More sharing options...
